First of all if i speak a little bit weirdly that's normal, i'm french.
I recently got a Xperia Z3 and i have some questions about it's waterproofness.
Can i use it in water with a low or high chlorine concentration ? I would like to know if I can use it in a swimming pool or in a spa with chlorine without be worried about water infiltration.
And i also would like to know if it's normal if my notification LED doesn't work well without an app like Light Flow (i mean it works but only when i recharge the phone and when i receive a message but it only flinks all the 10 secondes so all of this is not really usefull).
And last question, do you know a tool or something which I can root the Xperia Z3 without unlock the bootloader, to keep the camera brightness etc ...
Thank you !
Ok i won't risk it
And no i don't have the Stamina mode on, and without light flow functionning the led turn on just only when i rechage the phone and when i receive a text message (led flinking in white during 1/2 seconde around all the 10 seconds)
And too bad for the root, i don't want to unlock the bootloader and loose the warranty.
