Hi
This kind of problem is nearly impossible to fix on the forum.
I mean non of use really know what has resulted in the degradation of signal. Your phone has received hardware damage and it could be just anything causing your phone to behave in this way.
I can only advise you to have your phone examined at service center. They would surely be able to help you with it.
Just like Nabeel said, if other parts has been damaged (which it sounds like) a new back cover won't help. I do also suggest that you visit nearest service center to have the phone examined. You can contact your Local support for information about nearest service center and/or how to proceed with this in the best possible way.
