- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
Xperia Z1 - Sony PC Companion WiFi Connect Problem
dear
after i did my andorid update in my phone im not able to connect to wifi network
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Try to clear the connection or forget the connection from your list of connected devices then retry to connect if that fails then you could try the below
Performing a system repair using PC Companion will often fix issues - This will factory reset your phone and erase all data so best to backup before you begin
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi puppu,
Welcome to the community,
You may also want to try a simple Modem/Router restart, in most cases this will resolve such an issue.
let us know how you get on.
