dear
after i did my andorid update in my phone im not able to connect to wifi network
Try to clear the connection or forget the connection from your list of connected devices then retry to connect if that fails then you could try the below
Performing a system repair using PC Companion will often fix issues - This will factory reset your phone and erase all data so best to backup before you begin
Hi puppu,
Welcome to the community,
You may also want to try a simple Modem/Router restart, in most cases this will resolve such an issue.
let us know how you get on.
