xperia z1 shut down, wont start up
cappaghbaby
My Z1 Compact was working fine. I turned it off today to insert a new SIM and now can't turn on the phone. I have removed new SIM and still get the error
Unfortunately InitialBootSetup has stopped. I have tried restarting but no joy. Any Ideas?
Thommo
Genius
Try performing a system repair using PC Companion as this will often fix issues - This will factory reset your phone and erase all data
