Xperia z1 microphone issue after lolipop upgrade
abahopc
Since I upgraded to lolipop on my Xperia z1. My microphone has been didabled. When I make calls people can't hear me. It's very distressing please help!!! Urgently.
2 REPLIES 2
summy777
I bought z1 4 days earlier mine to same problm microphone issue and phone hangs many times dead ihave to do force restart. Music players volume not decreasing. Without restart apps not working what to do is service centre replace my phone to new one
SophiaW
Enthusiast
Hi abahopc and sumit3, welcome to the community!
Since this has occurred after updating your device - I advise re-installing the update by doing a software repair. This is very likely to smoothen out the OS for you.
To do this you just need access to a computer with an internet connection.
You will need to download either PC Companion or Bridge for Mac.
Note: a software repair will delete all user data, to back up your phone:
using PC Companion
1. Go to Support to install PC Companion on a Windows computer.
2. When installed, start PC Companion on the computer.
3. Connect your phone to the computer using a USB cable.
4. Click Start under Backup & Restore.
5. Follow the on-screen instructions.
(Exactly what contents will be backed up may differ depending on phone model.
You can view detailed information about this as you follow the steps in the Backup & Restore wizard).
using Bridge for Mac
1. Launch Bridge For MAC.
2. Select "Back up your Xperia device".
3. Select the data you wish to back up from your device (the windows can be expanded for more detail as below; then select "Next".
4. The backup will now be in process, do not disconnect the phone while this runs.
Running the software repair on PC Companion:
2. Phone Software Update.
3. Start.
4. Repair Phone
5. Continue
6. Accept data removal
7. Next
8. Wait for prepare
9. Select Phone
Running the software repair on Bridge for Mac:
2. On the Main Window select "Xperia > Repair Xperia Device".
3. Ensure the phone is charged and select "Ok" in the following window.
5. Wait until the initialising step is finished the continue as below.
7. Follow the connection steps that appear, ensuring that you are holding the relevant button down before during and after the connection phase until the update/repair begins.
I hope this helps! Keep us updated.
