Xperia Z1 doesn't turn on
sparks101
Hi. I have an Xperia Z1 and it kept on displaying an error about apps etc that doesn't respond then I switched it off hoping to fix this. The phone didn't want to turn on again. I tried to reset it and connected it to the charger it first didn't show the notification light but I left it for an hour and tried turning it on. It still didn't work and I used the power button with the volume up then it vibrated and the red light came on while its connected to the charger but the phone still doesn't turn on and it's been 6 hours allready and the light is still red and doesn't turn on. The pc doesn't detect the phone. Does anyone know what I should do?
7 REPLIES 7
Thommo
Genius
The only thing you can do is to try and perform a system repair and see if that fixes the issue
Start PC Companion and select Support zone then Update my phone/tablet then in Blue Repair my phone/tablet and follow the onscreen instructions - When prompted connect your phone still switched off holding volume down - This should start the repair or reformat process
Edguy555
SUS support is closed. Now use PC Companion.
sparks101
HI thanks will that work if the pc cant detect the device and pc companion says no phone is connected?
Edguy555
Connect your phone in flashmode (Volume down + Power button together)
Thommo
Genius
Thats not flashmode power and volume down - Flashmode is with phone switched off hold volume down and connect your USB cable
Edguy555
Yes, you are right! I made mistake in my description. Cable instead of power button.
