LTE doesn't work on Venezuela
JoelFloresA
Hi
While the phone says working in bands for LTA operator Digitel, it doesn't work propertied
I have the usim and active plan for LTE.
When I do the search networks LTE network appears, but when I try to connect the phone says I have no data network
Anyone know if it's an issue of particular settings that I should do?
Thanks in advance
2 REPLIES 2
DarkKat
Hi Joel, I went to Venezuela from December 2013 to Mach 2014 and got the same problem, When I got back to Colombia it works perfectly, now I went to Miami and the same problem is happening, Do you have a solution or an useful answer?
JoelFloresA
Hi DarkKat
No I haven't found any solution at all.
I think this is some kind of configuration ( on the operator side) adn we can't do anything.  :S
I was woundering what operator are you using in Colombia and also in Miami?
I'm still searching ...
If anyone know someting about it.. It would be very nice if write us.
Thanks in advance.
Joel
