Hi I have a problem driving me crazy. After every sony update installed on my phone, my phone no longer syncs contacts with my Parrot bluetooth. It seems the pbab access is no longer running and I can't get a request to access pbab. The only way I can get it to work again is to reset the phone and then I get the pbab access request back and then all is fine. But then I have to re enter all my acc info ,reinstall apps ,contacts settings etc. Is there another way??
You should not have to reset the entire phone every time you update it. If this happens again, try resetting your bluetooth handsfree instead and remove the pairing from Settings -> Bluetooth and then add it again.
