Xperia Z Ultra touch screen problems.
rhia
hi ! i really have a serious problem with my Xperia. Once I accidentally pressed the settings about the "TalkSetting", the phone won"t work anymore. how to fix this? and the screen also always vibrating and it seems it is hard to touch and it's malfunctioning. pleasw help
2 REPLIES 2
Thommo
Genius
Try performing a system repair using Pc Companion as this will often fix issues - This will factory reset your phone
Start PC Companion and select Support zone then Update my phone/tablet then in Blue Repair my phone/tablet and follow the onscreen instructions - When prompted connect your phone still switched off holding volume down or back button - This should start the repair or reformat process
If PCC doesn't work then contact your local Xperia Care
