I bought this phone (Xperia Z Ultra) almost a month ago. Few days back, I was facing issues with Dock and magnetic charger- it was continuously blinking with charging-discharging-charging. It was charging fine with USB port then I did an OS update with Sony PC Companion 2.1 but still the dock charging problem was unresolved.
I went to one of the sony center, they said it is unrepairable- take your backup and submit it. It will take some 20-25 days for a replacement. I took the backup at the moment and asked the front desk operator to process it. She took the phone inside, came back after some 15 mins with a statement- your phone is 'water-logged' and we cant take it. Battery level was low that time and by the time I came home it was already switched off. Now it is not charging even with USB port. I am unable to start the phone- Tried Power Bank, USB Charging, Dock Charging.
Any Suggestion? Sometimes I just can see the screen with 1% battery sign.
- Jayesh
Sorry but if it won't charge then items you want from it can't be accessed - if it is water damaged then this would account for the issue you have
Thanks Thommo. Fortunately it started charging from USB cable and I am using the phone but the issues with Dock and magnetic charger is still the same. I can acccess the phone now, any suggestions at this moment?
Regards
Jayesh
i have the same problem it sometimes charge with moove to certain position the cable but it is very difficult to put it right way to charge i bought an magnetic cable i hope this could be an solution
I have the same problem everyday to charge my device. I have to try moving cable continuously to get it to charge. and even with charging dock still having charging issues.
