This process will help you resinstall the old backup and restore on your x10 after the upgrade to Android 2.3.3
1. On your phone: go to settings -> applications -> 'check' unknown sources
2. On your phone goto Android Market and download: IO File manager
3. On your PC: Download this file http://www.elita-clan.com/downloads/...re_v010935.apk
4. Connect your phone to pc and copy downloaded file to your sdcard.
5. Disconnect phone from pc.
6 On your phone open IO file manager and look for download file on your sdcard and open it.
7. Follow instructions to install program and at the end click 'OPEN' to start the app.
8. This will now allow you to have the original program to restore your files back onto your X10
Hello,
I can't find my Back up & Restore application on my Sony Ericsson Experia X10.
Tried your eplanation, but the link you wrote down can't be opened after downloading. So how do I copy this onto my SD-card which is in my phone?
I really hope you can help me, because now it's hard for me to use my phone since all my data has disappeared.
Regards,
Brenda
I've downloaded the app as posted, but now I don't know what to do next.
If I open this app, I can't find the back up & resore option as mentioned in the message.
Hopefully someone can explain to me what to do (step by step, if possible!)
Thanks!!!
After re-inserting my SD-card it seems to work!
Thank you for the help and support. Now I can hopefully use my phone again!
Brenda
How to install it
You need to
download IO File Manager
download the backup & restore app, transfer it to your SD card, use OI file manager to find it -> tap on it -> install it
I'm glad you figured it out
It completely worked!
I'm happy with my SE phone again!!!
Thanks so much for taking the time to help others!
Thank you very much.....you LEGEND
Easy to follow and clear and more to the point 110% accurate
Thank you
