Xperia V - Extended Standby Mode and CalenGoo alarm/popup
Antenore
I had Extended Standby Mode and CalenGoo calendar working well togheter from the start of my experience with Xperia V (four months ago).
In the last few weeks I began to loose alarm sound and popup screen of my meetings from Calengoo. Nothing at all, until, after several tries, I arrived to disable Extended Standby Mode. After that, Calengoo works fine, but... my battery is no more so performant.
Any idea for a solution?
Thanks in advance
7 REPLIES 7
There isn't a way around it as extended standby mode will stop this notifications so your battery last longer
Antenore
May be, but I don't understand why it has been working fine during three months... And then it stopped with no apparent reason.
Probably an app update
Antenore
I read somewhere that Stamina mode has a white list, where you can state which apps remain active when screen is off.
Nothing similar in Extended Standby Mode?
profile.country.RO.title
_alexdon_
If you tap on extended standby mode in power management,doesn't it take you to other settings for it?I cannot remember since I had ICS.
alexdon
Antenore
No, just a flag to activate/deactivate ESM.
Tapping on has no other effects
_alexdon_
It means you cannot add exceptions.
alexdon
