I had Extended Standby Mode and CalenGoo calendar working well togheter from the start of my experience with Xperia V (four months ago).
In the last few weeks I began to loose alarm sound and popup screen of my meetings from Calengoo. Nothing at all, until, after several tries, I arrived to disable Extended Standby Mode. After that, Calengoo works fine, but... my battery is no more so performant.
Any idea for a solution?
Thanks in advance
There isn't a way around it as extended standby mode will stop this notifications so your battery last longer
Probably an app update
I read somewhere that Stamina mode has a white list, where you can state which apps remain active when screen is off.
Nothing similar in Extended Standby Mode?
If you tap on extended standby mode in power management,doesn't it take you to other settings for it?I cannot remember since I had ICS.
It means you cannot add exceptions.
