hey! guys I am unable to run android apps on my xperia u but my browser is running perfectly.
On opening any App it shows "check your network settings".
plz guys tell me something about it.:-/
what app are you trying to run? try clearing the apps's data, settings>apps>manage apps> look for the app and tap on clear data.
also check if you have the correct apn from your network
all android apps. Even I am not able to sign in the android market and I should tell you that i have just bought
XperiA U.
everything? like those apps that does not use network?
I suggest that you repair your phone with SUS/PCC
also dont forget to back up important data.
I think you have to get correct APN from your service provided. If already done select the same as default in Wireless& network settings>access point names. Also check you have selected preferred network to WCDMA (preferred)/GSM.
Hope it works.
thanks, the probem was with APN and now the apps are running correctly except i am not able to register to google talk.it says "google talk: authentication failed". can you tell something about this?
may be password problem (wrong) .
are you from india....???
I have CORRECT answer for you....!!!!
select your apn as internet....
means as you know that , for ex tata docomo comes with three apns wap, mms and internet....!!!
so use internet as apn...!!!
and also there is a little problem for connecting....!!!
so try switching on and off for data connections.....!!!
it will surely work...
thnx, i selected my apn as internet but still i am not able to dwnload any app from android market.
i signed in android market and it opened correctly but when i tried to download opra mini, fruit ninja and
TED app, it started but showed "downloading" for a long time and then the result was "downloading failed". i tried a lot of times but got the same result.
what should i do???
is it some kind of a network problem or problem with my android system???
also, on selecting the apn to internet i am not able to run my phone browser.
And! yes, i am from "INDIA".
