My battery is dropping to 15% then when I put it on charge, it's still dropping. The phone has died on me 4 times already today. What do I do? I've taken the battery out, but still nothing. I need to charge my phone to go out, how do I fix this please?
No matter where I charge it, the charge symbol is showing but the % is going down rather than up. doesn't make sense.
help would be appreciated. thanks.
How are you charging your battery? (Wall charger or through a computer)
Wall charger.
Repair your phone with SUS if that doesn't work then take it to a Sony repair center
Update Service (SUS)
Bridge (for Mac)
can't use SUS because it needs at least 50% charge to update. i can't charge.
ok try this
Press and hold power & volume up for 5 seconds > connect the phone to the wall charger > press and hold power & volume up > let it charge for 1 or 2 hours
also, are you using Sony's charger and/or usb cable? or some other brand?
Try this
Take out your battery and wait for 30 second
Then put it back into your phone and charge it without booting the phone
Wait at least 20-30 minutes then try boot the phone
I tried using the SUS and rebooted the phone and reinstalled the software. Still slow, battery still doing the same thing. I tried the volume up power thing, no change.
