I had exactly the same problem. I got mine on 3rd Oct, and after about 7 days of use, I discharged the battery to 0% and it automatically turned off. Since then it refused to charge when power off, and as I have 0% battery, it cannot be turned on, making the phone totally unusable!
I finally managed to get it work again, here's the steps if you also find your phone dead.
  1. When 0% battery and auto power off, if you press the power button, the LED light should flash quickly a few times and off.
  2. Now press and hold the power button and when LED is still flashing, plug in the charger (use wall charger not USB on PC). You should remain holding the power button, otherwise the LED will turn off and no charging again.
  3. After about 5 min, it will be charged to a minimum amount required to boot and the screen will be turned on. Now press the volume up key while still holding power button to reset the phone.
I saved my phone just like this, but even now it still cannot charge when power off. Searched this forum and some say it can be fixed by changing the chargemon file? It would be much appreciated if someone can share it.
