I have an Xperia T LT30p model, and suddenly my wifi and bluetooth stopped workig. I can turn on them in my settings but i cant find any network or device. Even NFC or AP isnt woking. Please help me!
Regards,
Lazic
Hi mare96po,
This is unfortunate, and may be related to hardware, however you can try a few things to rule that out. The first thing I suggest would be booting the device in to safemode to see if they work or not. Use the link below for instructions.
thanks for your fast response. Safe mode doesent change anything. Stil cant find any network or device. Any other solutions?
Regards,
Lazic
Are you able to see other devices or does it only show an empty list?
Only empty list.
This has been going for an year. I was trying to find solution online, but no one had same problem or had a solution. So i finally decided to post it here.
And now, few minutes before i posted this, my mobile data also stopped working. Same issue, i can turn it on but nothing happens. Looks like my phone is dying...
You could attempt a software repair on the device to see if this is software related. Use the link below and go through it. Once done let me know the results.
Don't forget to backup the handset with PC Companion as well.
