After a missed call, sms, etc. my phone's LED is only on while the screen is on. Once the screen goes off the notification led shuts down as well, which defeats the whole purpose of having a notification led. I have tried using the Light Flow Lite app but the result is the same - the led shuts down with the screen going off.
I have not found a solution here on the forum. Can you please give me a hint what to do?
Thanks a ton!
Try "repair your phone" with SUS or PCC, this is a standard sony support team's answer. It's a bullshet.
Make sure Battery Saving Mode is off for Notification Light to work properly.
I personally use Missed Message Flasher for missed calls and texts,
you can light up screen or just tone etc and edit times.
Yes you right, it works.
But I need the Extended Standby Mode, it's power saver. This JB is still full of bugs.
