Xperia SP Left LED Problem
Sachin11
MY Xperia SP is having a problem with left LED of the illumination bar.
Left LED shows different colour then the other two LED's......
PLEASE HELP!!!!
7 REPLIES 7
Bee-Ant
As for me, my left light is turned on with faint white light when the screen is on and showing any app other than gallery and walkman
Akkush
Disable the firmware default lights and use alternative softwares ,like Illumination bar !
Sachin11
Having same problem with th illumination bar app after turning off the fimware default LED...
You can see that the left LED is Showing different colour than the other two LED
Akkush
Hmmm. Strange. Try factory data reset the phone. (settings/reset-backup). Do not backup/restore the settings. It will erase everything !
If it wont help... I have no idea.... Maybe service center ?
good luck ! Slightly_smiling_Face
Danial-mach1
Leader
try 3rd party apps and see the same happens?
also try safe mode
thamjid
It may be a hardware problem. That yellow light is produced by 2 LEDs. Red and green. Check the green led in the left side is working or not. You can checkbit by opening a greenish image in album app.
Sachin11
THANKS MAN!!
I think you are right. The green LED is not working..
KUDOS to you!!!!!
