Xperia SP lags while in settings
PanosGR89
Hello guys,
After the latest update the phone has become very fast and smooth, as it was with 4.1.2. However a bug still occurs (it started with the first 4.3 update) some times. When I go to settings and clear cache or ram management my phone starts lagging out of nowhere. The weird thing is that it doesn't freeze, it works and I can scroll and move around the menu or whatever. However, nothing actually works, for example I try to open viber but it doesn't show messages etc. I have to hard reset my phone as I can't even turn it off pressing the power button. It's getting really frustrating. I installed the latest software with clean install using SUS and performed factory resets before and after updating.
19 REPLIES 19
PanosGR89
I booted my phone to safe mode for several hours, used it as always but the problem didn't occur. What app might lag the phone when I am in settings >apps and for what reason? That's very weird.
profile.country.RO.title
_alexdon_
Any task killers,battery savers you have installed?
alexdon
PanosGR89
Nope.
_alexdon_
Are you willing to try a software repair?
alexdon
him
Looks like some 3rd party app is causing this try to pinpoint the app then Uninstall.
PanosGR89
What kind of app might cause this problem when I am in apps - settings? It doesn't make any sense, as u don't have this problem at any other point. Yes Alex I am willing to do a software repair once again, I would like to ask something first. What if I perform factory reset, then install with PC Companion (I used SUS the other 2 times) and then factory reset again? Do you think this could be better or just try and see what happens? Thanks for your replies guys.
PanosGR89
*as I don't have
The other option would be to let it be as it is and not go to settings this often, only once in 2-3 days to clear cache.
_alexdon_
You should first reinstall with PCC or SUS,after that do a factory settings reset.
alexdon
ragesh
I'm facing this same problem. Slightly_frowning_Face
_alexdon_
ragesh,did you try a repair?
alexdon
