Xperia Sp charger
GreekXperiaSp
Xperia Sp charger
I charge my phone with a 1.5 amper charger..its nkt Sony's product...will this affect my phone?
3 REPLIES 3
Thommo
Genius
No - The Voltage is the main thing to note - The Amps is how much power is given out - So if a Sony charger is 1 amp and you are using 1.5 amps then the only thing you may notice is a very slightly faster charging time - Which can over time mean the battery life is reduced for example instead of it been say 5 years before a replacement is needed you may need to replace after 4 years and a half years give or take
razvan
Hello,
I am not a specialist but i will also not recommed the ussage of other charger
On the other hand i doubt that averrage life of keeping a mobile is higher than 2.5 years Slightly_smiling_Face
andri211
Xperia SP support fast charging
But that can happen if using sony cable and sony charger. Others than that it only give you 1A.
I have tried charging using 1.5A non sony, my phone is hot, considered to buy ep881
