xperia sp 4.3 problem after updating
gre
Just after update to 4.3 when screen times out the screen is flickering 3-4 times as the brightnes goes away, i mean the screen timeout transition is not smooth. Anyone have this issue?
59 REPLIES 59
damo29772
i have flickering and i  updated with sus everything else good :smileysmileythumbsup:
DanielWu9790
Having problemS (plural) here too.
1. The screen dims all of sudden every now and then; 2: Volume bar doesn't show.
3. Some spontaneous reboots when out of ram.
It makes me wonder how was this update tested, if it was done on an emulator or how. Because Problem 1 and 2 took me minutes to notice, and I'm not the only one.
Loved many, many things about the update but please improve quality controls, 'cause I can't understand what happened with this.
stealthfighter
The personal contact picture does not appear in the SMS conversations. Tried all sorts of deleting, replacing, and editing but still it doesn't appear. Wifi notification shows stronger signal but still keeps on randomly disconnecting.
killbill_
Well, I fashed 4 times the ftf. The first from the PCC , the second from SUS, then an ftf firmware of another region and finally again from the SUS - Every time with a factory reset.
Nothing changed the screen was flickering by the time the boot animation stopped.
I noticed it is more vivid when it comes to grey colors. In total black everything looks fine.
So if you don't want to roll back to 4.1 ,turn off autobrightness and set screen brightness at 30% aprx. It will be less noticeable.
Notice that the phone was working flawlessly before that.
Eventually we will have an official answer soon.
Patient we must have Nauseated_Face
Johnson
After update when we try to up or down the volume its showing a black bar on screen insted of volume status.
Johnson
Any one try sence me channel. For me its not working. Its showing count but not playing.
Danial-mach1
Leader
@killbill choose default theme and reboot..it will fix.
@Johnson sense me channel work fine for me
killbill_
Still the same.. Thanks though !
papa_georgio
Umm anyone else noticed that the volume of XSP after update is so low ? I mean notifications / headphones, everything 😕
zpl12
i have a problem with volume indicator in tri flat theme , it appears a black bar... cand anyone help me ?! Screenshot_2014-02-15-10-28-37.png
