Hello guys,
In 23.1.A.1.28 theres a problem with importing Contacts (.vcf files) from internal or external SD.
i deleted data from contacts apk, but i doesn't helps. I make a fullwipe once a week, so it should not be a problem of my flashmethod or configuration.
Anyone have the same issue?
I'm able to import a .vcf file both from internal storage and the SD-card, could you please elaborate? What happens when you try to import a .vcf file? Do you get any error message? Is it contacts that you have exported to a .vcf file directly in the phone or from where have you got the .vcf file?
Have you checked the filter? Make sure that the filter is set to default and that it has not been set to show Online contacts only etc.
Let us know how you get on.
