i have bought my xperia sola about two months ago and it worked fine for the 1st month. nut for the last one month the touchscreen all of a sudden started to creat problems. Most of the times i have to tap 4-5 times on an icon. some of the parts of the screen have become totally unresponsive. I have tried everything cleaning myhands, cleaning the screen , software upgradation ; but nothing works. It is also not the problem of the screen protector as i have also tried after removing the protector. A few days ago I have seen that whenever i take the phone under direct sunlight for 5-10 mins the touchscreen works smoothly for the next 1-2 hours. then the same problems occurs again. What Can i Do now? Please help. I am feeling Busted.
dial *#*#7378423#*#* service test > touchscreen. post the screenshots here
what will you understand from the screenshots?
when i take the phone under direct sunlight for a few minutes it starts to works fine for the next 1 hour. which means this is a problem with the hardware.WHat can i do now?
I suggest getting the handset back to the place of purchase or to a service centre for repairs, I have supplied a link below that will allow you to find contact details of Sony Xperia Support within your region.
I bought sola in july past 3 weeks i had the same issue,
after following this forum i tried SUN light, its SUPER working as of now,
i remove the protective screen and tried this and wont put the protcetive cover,
before tring this I updated my phones image.
@dnmachar - Really? But till now iu have not find any permanent solution of this. What did you mean by "updated my phone's image"? Did you tried by flash the phone?
Yep, i updated my pc companion with 'update service' found in this blog and updated or flashed the phone, but it didnt work out. finally i planned to take to service centre but then i thought i will try keeping in sunlight[ this was for some 20 mins in sunlight].
its 7 day now and its working super, i havent put the protective screen and wont put.
I have the exact same problem on my new Xperia Go and it seems like a manufacturing defect with the touchscreen of the Xperia Sola and Xperia Go as reported on many user forums. You can check the extent of the problem by running the touch screen test in the "service menu" (dialing *#*#7378423#*#*)
Running my finger all over the screen on the touch screen test, I see that big parts of the screen have lost sensitivity. Too bad it's not sunny here lately so I can't try the temporary solution of exposing the screen to sunlight. My guess is that the problem has to do with the bonding of the capacitive touchscreen layer to the outer glass layer. That's what happens when you outsource in China. If the company is respectable, they should have a global recall for this issue. Go to the service centre and show them the result of the touch screen test. Mine was purchased on the gray market, so I'm sure they'll find a way to say it's off-warranty.
