Xperia Sola not charging
Fiqq
hello
I have a problem with my xperia sola can not charge ..
when connect the charger, LED indicator light flashes red and a few moments later sony logo came out, but it does not last long LED light back off and have to press the power button or connect over again to turn on the LED indicator it again .. and so on repeat again and again
anyone can help? 🙂
11 REPLIES 11
sethunath
I also have exactly the same problem with my sola
C_sony_sola_14
I solved it
I knwo this is after long time
but im writing this to help other who ever suffered from this issue
your previous was realy helpful to solve this.
My phone is Sony experia sola
yesterday it had been turened off while it was in my back pack.
I tried to turn it on by pressing power button but it ddnt work
only gave red blink.
i didn't hv a charger on that time .so i came home and tryied to charge it
using my charger, but nothing happend. charging red LED was not there
i tried to reset. using power and volume up button,ddnt work.
i tryiied few mor times,some times it shoved sony logo on display but
it got disappear within few swcond. some times it gv stable red LED
but after few min it blinked fast and disappeared.i also used different
cables too.
finaly it become a brick
no response only one red LED blink when it connected to charger
no display. then i pinned the charger pin slowly and stopped if it
gives a stable red LED. it seemed like working but that also
disappear after few attems.
i tryied the plug charger afetr only reseting it using power and vol+ button
it seemed working. i got red LED but no display. i kept it in the charger and
phone automatically displyied  sony logo and worked as nomlly. it was
copleatly turned on. but it still ddnt give chrging red LED. but it shows chrging
in the battery icon on the up line. i restarted using same methode and
battery was keep draining. then i used differnt cable  , it ave the charging red LED
and it got green suddenly and disappeard. then i connected it with ma original charger
now its working,now it's charging
dont give up you may have to do so many time to brig it back.
keep trying.
