Hey,
I get this error when trying to send files from my Xperia Sola to my PC. The two can't be connected via bluetooth because the Xperia doesn't have the driver stated on the subject. Please help!
I did try downloading the drivers and then installing them manually using device manager but that didn't work either. My PC says that it is unable to find the driver. (Dell Inspiron 15r, Windows 7)
That's odd, but on your PC install PCC or SUS > restart your PC > run SUS or PCC > connect your phone (USB) > your PC should download the drivers
Don't forget to give kudos
Update Service (SUS)
Bridge (for Mac)
Don't forget the Kudos
The problem is that both of these programs reset my phone to factory settings and upgrade it to the latest software, i.e. ICS. I don't want ICS. It will make my cell very slow. Is there any way to fix the bluetooth and keep the current Android version (GB 2.3.7) too?
You have to update there isn't quite a way around it, I would recommend that you stop by the XDA forum you might be able to find something
