Xperia SL Charging problem!
Subuktageen
My Xperia SL is on ICS
It works fine but only issue is sometimes the charging is too slow and sometimes it does not charge at all, i mean it connected to the adapter and the orange light is on but the percentage does not seem to increase, it remains at the same point.
I have factory restored it two times and when i do it chages a bit bu after some time it gets slow again.
I need a solution for this bcz i have put a lot of my money to buy this phone.
Plus the JB update is not yet released in my region.
This is my very first and very bad experience with Sony phone btw.
5 REPLIES 5
if you charge through a computer it will take longer and if you are using the phone while charging through a computer it might not charge at all.
Subuktageen
not charging from computer, using the adapter provided with the phone plus i have another charger of xperia sola so i tried with it as well.
Rameez_Ali
I had the same problem after updating to jelly bean. Tried everything, but a hard reset somehow solved it. To do that press volume up+power buttons at the same time.
Subuktageen
yes i have tried that bro, but it does not do much good. 😕
Subuktageen
Just updated my phone to Jelly Bean and now its charging fine. 30% in 10 to 15 mins...
