hi long story short my xperia s has been dunked in water four days ago everthing is working on the phone again apart from the display yet i can use hdmi cable and watch streaming on my tv
does anyone know if my display will come back on or do you think it is probably goosed
Probably goosed - SAFC don't suppose you're from Sunderland as I am
the only chance for u to make it work again is first off:
disassemble the first cover,(i believe its 7 screws) unplug the battery, and then put the phone along with its battery in a bowl filled up with rice (not cooked) and keep it for like 48hrs... just bear this if u want to rescue ur phone from being bricked lately
this method was tested on some phones and it successfully survided after being sank in water.
my phone has been in the rice already for about 3 days with first cover unscrewed only the dispaly is still not working
did u try air/hair blower?
if no, make a try with a cold air blowing.. if its possible disassemble the phone apart until u reach the display part....
here is the disassemble tutorial in a PDF file
http://www.sonymania.cz/storage/1331...peria_s_wi.pdf
Good luck buddy
Sorry, i think the direct link to PDF file doesn't work like that.... here is the whole page link, but as u can see the the previous msg, the link content... it's a 7MB PDF file with a 90 pages
