I'm using Ol File Manager to copy/move files from one folder to other folder. Here i found one issue when i connected my mobile to PC.
Created NewFolder from my device
Moved set of files to NewFolder
Now Connected to PC
I found that No NewFolder is created and the files remain the same old path.
If again i check in my mobile I can see the NewFolder and Moved files within that folder.
Can't we move files permanently as we wished to do in PC? Please suggest with your comments.
Already tried ASTRO File Manager, ES File Manager & Ol File Manager. In all these apps i face the same issue only.
Device - Xperia S - LT26i
Build - 6.1.A.2.55
Android version - 4.0.4
Thanks,Prabhu.
This file managers are the worst. Try to use Solid Explorer. It's the best.
The directory image on the phone doesn't update which is why is seems it doesn't exist. Rebooting should show it by refreshing the image on boot.
It's a total pain in the arse especially when downloading a file to the phone then trying to transfer it to a PC, and it was brought to the attention of Sony support over 8 months ago. Such a simple issue to fix.
As you can see it hasn't been rectified, there's a theme here...
