My xperia s is taking a long time to charge. frm 15 to 20% it nearly took an hour. it takes10 mins to increase 1%. someone pls help me out..
The values you mentioned above are when you charge via wall socket ? or laptop/ PC
Anyways no matter what type of charging it is, it shouldn't take this much
Do this
Press and hold Power Button and Volume Up button at the same time and hold them there for 10 Seconds. That would disconnect the battery .
See if it behaves in the same abnormal way, if yes, then go for a software repair
________________________________________________________________
SUS ( Sony Update Service) ... download and install it on pc and follow the on-screen instructions
