Xperia s camera slide problem
chanidu
I have Xperia s phone.I update it to jelly beans 4.1.2 from sony companion.But there is no camera slide option in lock screen.How it fix??please help me...:smileycry:
9 REPLIES 9
Johan
It should be there to the right of the lock screen clock.
I suggest that you try to run the phone in safe mode to see if it appears or reset the phone.
chanidu
I did it.but unfortunately there is:smileycry: also no camera slide opton in lock screen..plzzz help me soon...
Johan
Which build number are you running on?
Settings > About phone > Build number.
chanidu
6.2.B.1.96
thnx for consideration..
chanidu
pzz help me.........
Johan
I just reflashed a Xperia S with the very same build number and the camera slide on lock screen is still there.
So I suggest that you try to reinstall your phone using SUS and check if your able to get it back.
chanidu
It also i tried.but not fixed yet....
chanidu
plzz tell something and help me......
Johan
In that case the only thing I can think of that may cause this is if your software has some kind of network operator customization, where this feature is not available. I suggest that you contact your local support team to check this.
