Dear Sir/Madam,
I am a big fan of SONY in all aspects. But unfortunately, my Xperia S camera doesn't work properly. When I turn it on to take photo, after some seconds, it turns off and on and it happens many times. When I am taking video, it happens again and stops recording the video. Now it seems that my Xperia S powerfull camera is useless for me. Please help me to fix the problem. I have set it as reset factory mode and there is no difference.
I am in New Zealand now and don't tend to lose my time here.
Regards
Behrooz
Apart from the factory reset have you tried to run a repair using SUS found here - Download, Install and follow the onscreen instructions to run a repair
There is no "Xperia S" in the models. What should I do? Which of them I should select?
Make sure to "scroll down"
i have done! there is not. are you sure that there is "xperia s"?
It is there, right next to the Xperia Acro HD
uli,if you remember someone else complained about the 2012 models not being in SUS.Could the SUS version differ or what could be the issue?
SUS on startup will scan for updates download and apply and only after doing that will it fully startup for use
Ok,but why does it not find all the models?
Don't know which models are not been shown but below in my link that I've taken of SUS with the Xperia S
