**I speak spanish, so, sorry if my english is no too good
I have an xperia ray with android version 4.0.4
In my phone: settings>more..>mobile networks>network mode
But the network mode is disabled and below says: Change network op. mode.
This not happen in my previous android phone (another xperia ray), and when I accessed to network mode, I can choose between WCDMA only, GSM only, and WCDMA/GSM.
Why in my actual xperia ray this happens?? how i can fix that?
Thanks!!
If you have a branded phone, that means that it has been customized by your operator for example, it might be that they have "greyed out" some options concerning for ex networks and so on. Most likely that is what have happened in this case I'd guess.
@xperia support:
Even I have the same issue, however as you have mentioned above, in my case its an unlocked version, have used multiple carriers. able to make calls, browse, SMS, etc... but unable to switch network mode.
Do you guys have a solution for this? If you do not have, then I may have to think 100 times before buying a Sony next time, coz i purchased 2 phones xperia SL and xperia P, both have the same issue.
Hi Guys,
Even i got an Sony Xperia SL mobile phone, for me also the same issue. but the nework mode worked once after that it's disabled.
Let me know any one gets a soluion ?
-- Kumaravel
I dont have a solution, but i discover that in service menu (dial *#*#7378423#*#*) we can change the network mode. I dont remember exactly where we have to access, because i dont have my phone right know.
Thanks Jose, yesterday when i digged more ... i also got the same solution,
1) type *#*#4636#*#*
2) It will take u to Testing menu, select "Phone Information"
3) Select the network mode in the drop down
It's working for my set, please try out.
Yes, that works too.
Thanks!
i'm able to change the network modes from settings itself now, after the update to
6.1.A.2.55 build today .....
I heard about an update to 4.1.B.1.13. But havent received yet.
That update..., you just plug in the phone and open PC companion? (I dont have my usb cable, thats why i havent plug in my phone)
It's through PC Companion.
