Xperia ray auto shutdown
Sebastian1987
Dear,
I have noticed some strange behavior of the phone.
When I'm listening to the radio it sometimes shuts down by itself with no warning message with a fully loaded battery.
It happened again yesterday, just black screen and than I have to start it again.
It does not happen multiple times after another but just random and after restarting it it works normal.
Can this be solved ? I have the latest firmware running.
Thank you
Sebastian
Hampus
There might be a third party app that is causing the problem. I suggest that you boot the phone into safe mode to see if you experience the same behaviour:
http://talk.sonymobile.com/t5/FAQ/How-to-boot-your-phone-into-safe-mode/m-p/348008
Otherwise, I suggest that you perform a software repair on your phone via PC Companion:
http://www.sonymobile.com/global-en/tools/pc-companion/
In PC Companion you press start on Support Zone > Start on Update the phone/tablet software > Repair phone/tablet (the blue clickable link in the message) > Follow these steps without having your device connected to the PC.
