Hi,i have some issue with my XPERIA P
After a standby mode , i become unreachable but signal bar is full,i'm also not able to perform any call...everyting look like to be ok.I need to switch off/on my phone or enable/desable the airplane mode to fix this issue.
It mostly happened if phone is in standby mode for longer time(always seen when i wake up in morning).
Android Version:- 4.1.2
is there any solution?
Thanks in advance
Maybe stamina mode interacts with your phone's functions.Try to disable it and see if there is any difference.
I have tried both (enabled/desabled) but same issue.
Have you repaired your phone's software until now?
No
If you are willing,you can repair your phone software with PCC or SUS.If you do not want to do that on your own,take the phone to a sony authorized service.
Repaired. But same issue
The only option you have is to take the phone to a sony center,they can have a look and see what is wrong.
This problem sounds very familiar to me.
I have the same problem !
My phone has been send for repair: no improvement.
I have done all the tricks mentioned in this treat: no improvements.
I only see a solution by switching off WiFi. In that situation I haven't seen this problem..... .
Within soon I will change to Samsung as I have had it with the poor quality and poor service of Sony. Just waiting for a smartphone with the same bright display in sunlight as the Xperia-P.
Few phones have this display on the market,maybe you can have a look at the ZU,with the triluminos display.
