XPERIA P :ICS UPDATE DRAINING BATTERY LIKE COUNTDOWN
danzy
hi people i have an issue dont knw y but mine xp worked best in gingerbread version , then it had no battery isuue or ne issues now wen i have updated it to ics i found a problem with battery , I CHARGED MY DEVICE WITH USB AFTER 60% IT DIRECTLY SET TO 100% CHARGE AND IT STARTED DRAINING LIKE A COUNTDOWN TILL 1% AFTER 1% I PLAYED NFS AND MADE 1 CALL BUT THE DEVICE DIDNT DISCHARGE OR TURNED OFF AS IN GINGERBREAD IT WILL SHUTDOWN @ 2% CHARGING ................. DONNO HOW TO RESOLVE THE PROBLEM I AM A FIRST TYM USER ............ TENSED SONY SUGGEST ME PLZZZZZZZZ
12 REPLIES 12
profile.country.PH.title
MarlonUk1
Gingerbread is more stable and better performing than ICS.
i suggest to perform a software repair using Sony Update Service.
and please take note of the apps your are installing as they maybe acting up and causing this problem.
danzy
i havent installed ne thing ............. its just is not gettin stable. i have put to charge thru charger lets c . i know its not battey problem but the software app for battery meter is not working . i will wait a day if it gets organised .
MarlonUk1
hmm. try a settings reset, it would restor default settings without deleting your data.
danzy
did it just now got 100% charge lets see in couple of min i will know the answere
ryan515
you could reset all before you repair.
apjain
Checked the battery consumption in power management, more that 50% is consumed by Android OS. In gingerbread, the maximum was by the display screen. In case of  ICS the display screen consumes only 9%. Any body facing the same issue? Any idea how to fix it?
adishenoy
Even I have the same problem and I don't have any games installed on my phone. It just goes down like countdown (not very fast though). I think its a bug and a bug fix is probably on the way.
AdityaRao
I am faceing the same Prob here in the SC
As you can see I went to college leaving the phone at home.. played 2 to 3 songs before taking this SC
Daniel_92
As you can see I have no problem at all, after I've installed the ICS on release. This result is after a daily use. Or am I wrong? 32% is too high?Screenshot_2012-08-29-20-31-14.png
