Low Volume Problem (xperia acro s)
Kain
how can i volume up with headphone ? to low volume. its not good. this is not sony walkman ... when i try volume up access denied.. i can only use %50 volume up. and xloud doesnt work. need some help. sorry for my english..
5 REPLIES 5
midniteman
I have the same problem. If a headphone is connected and I turn the volume down, it sinks down to very low and can't be readjusted to maximum. If I then pause the track and restart playback, volume jumps back to maximum. This is definitely a phone bug, because I tested with different headphones and different music player apps. Very annoying if I want to listen to music during sports. Sony has to fix that asap.
Sparda
so no answer ...
Johan
When this happen you should be able to see a pop-up which you need to confirm that you are aware of that high volume can harm your hearing. This pop-up comes from time to time when listening to music for long periods of time.
Sparda
walkmans too ? cause walkmans have high volume or another models ? "This pop-up comes from time to time when listening to music for long periods of time." Not same walkman and arc s or other models ....
"When this happen you should be able to see a pop-up which you need to confirm that you are aware of that high volume can harm your hearing. "
i cant confirm. Doesnt work.
i think we need new headphone. this handphone not have good quality (mh650c)... and only mh650c able to work on acro s. so very good..
shinichixxx
use sony wireless stereo bluetooth headset, the phone system volume well low to 40% . but u still can hear your incoming call ringtone via wireless stereo bluetooth headset.
