My phone ( sony experia p LT22i) had low battery status this morning and as usual I did charged it , but after half an hour charging im trying to switch it on and it doesnt working, it appears red orange light and thats it, i did try reading some of the related post and try the suggested repair but it didnt work. I did try holding the power and upper volume for ten sec the charge for two hrs but doesnt work, I did also Pc companion but the problem is it couldnt connect to my phone it says error with the connection. i dont know now pls help,
When on charge do you see any indication that it is charging - You may need to check the charger is working correctly and it maybe that you need to perform a system repair
To perform a system repair - This will factory reset your phone
Start PC Companion and select Support zone then Update my phone/tablet then in Blue Repair my phone/tablet and follow the onscreen instructions - When prompted connect your phone still switched off holding volume down or back button - This should start the repair or reformat process
