Hi guys, i bought an Xperia U and when i took a photo without flash it was great but when i took it WITH flash, it was blur and a little yellowish. Later i came to know that the camera lens was covered with a plastic sheet. so i removed it and the issue was solved.
Recently, i bought an Xperia P. same is the case with it. without flash, it is great but with flash it is yellowish and less details. also i have figured out that the camera lens if placed at a specific angle with the light, give a bluish shade. while the lens on my Xperia U give white shade. So i assume that the xperia P's camera is also covered with sore sort of plastic sheet, that is why, with flash, it reflects and the result gets disturbed. But at the same time, Xperia P is a non-removable back phone. So can anyone look into this problem.
Thanks.
i own a P but if you're having troubles with camera then maybe you should repair your phone using SUS or PC companion. and with the plastic cover on the camera of xperia P i think you wil be able to see it if theres something on it.try repairing it and post back if it doesn't work. = )
