Xperia P .100 Updated-Problem identified
shirabthinath_n
I just now updated to Jellybean 4.1.2 .Following problem has been identified.
  • Call Lag problem
        1.   It takes 3-4 seconds and 4-5seconds to load the call log history.
        2.   When i click on a contact to call ,it takes 5-6seconds to go to calling screen but i noticed that call was already in               progress
        3. When i receive an incoming call, phone rings only after 5 seconds, Caller on the other side will get 2rings before i              receive a call in the phone.
Really got disappointed with dialer/phone app. Soon a update must be released both for white background and lag problems
  • Screen not responding
        1.      I noticed that when i keep the phone in charge, the screen is not responding correctly. i.e no response to touch screen.
  •   Kindly don't provide the same reply. i.e restore.reinstall. Tried all methods but none of them work. Request you to post the problems you faced in Xperia P (.100)
2 REPLIES 2
shirabthinath_n
Kindly reply the solution for the problem
jackxperiaP
i don face the call lag , even before factory reset and aft reset too ,,
kindly follow this and check once again with patience..
1. factory reset
2. update with SUS
3. factoory reset
4. again update with SUS(this step is optional but try this too)
Important: kindly do not touch ur phone when it reboots each time during the procedure of the above steps .. wait atleast 10 min to let it settle down..
