Xperia Mini Pro Sound Problem
I Hv Buyed My Phone In August N In starting It Was Good To Hear Music Bcoz Sound Quality Was Very Good at that time.
Now Its Very Ordinary.
I hv Compared My Phone Sound To Other Mini Pro >>>>
My Phones Sound Is very Bad compare to His.
Some Time Its worked  Fairly... After Receiving Call...
But its Goes Off Also If I call Some one or Plugged My Earphones..
Pls Help Me If Solution Is available..
I hv upadated my Today Thn Also The Problem Is same..
i hv done factory rest also..
will i go to service center for the solution or can i do it own...?
9 REPLIES 9
gwhispererz
Hi, have a look at your sound settings.
Goto Settings>Sound, make sure xLOUD is ticked.
YA I hv tried ths also but the sound output is same as it was..
but thnx for repying
gwhispererz
The other place to check is of course the music player equalizer ....
Ths also i hv tried...
in sound settings i hv done full sound...
equaliser is also set...by me
one thng i want to mention u is that...
some time when i play vedio on my phone the sound gets perfect....
but aftr some time it again get worst...
plz suggest me wt to do now
gwhispererz
No sure if it is due to the quality of your music and video files?
One important point to note .... be sure not to cover the speaker (located at the back of the phone) while playing music and video.
i do take care of ths thing...
im worried bcoz the same problem is vth my friends set also.....
gwhispererz
I can't think of anything else .... I believe you do take care of your phone, therefore will never blast at full volume (can definitely damage the speaker).
Since you have just updated your phone and still having this problem, I think a Software Repair is quite meaningless.
Hope that SE Service Centre can assist you regarding your problem. Slightly_smiling_Face
Ok If They Found Any Hardware problem will they Charge for repairing it or it vl b done free of cost as the set is in warranty period.
gwhispererz
SE Service Centre should be in a better position to clear your doubt on this.
They will let you know after their evaluation of the problem.
