Hello,i noticed that xperia mini has an overheating issue so i manually updated to ics.After 2 minutes i said '' i will wait for the official update to come'' so i revert it back to gingerbread with the firmware that i have backed up on flashtool but after the downgrade i noticed that overheating issue have gone so now i am using all the time my phone without the overheating problem.Why is this happening?:smileyplain:
Why did you revert back ? Overheting - captive buttons is solved in ICS. And with the flashtool you have get the official ICS. Its a bit different from thoose that you could get from your carrier. Perhaps with flashtool you will not get the bloatware applications that your carrier preinstall in the image.
I would leave this ICS version running.... only if you are afraid what will happen with warranty if someday need.
i revert it back cose i said i will wait.I like gb but now it is better with out overheating
P.S: my video camera quality when is set to hd 720p is horrible why is this happening ?
