Xperia mini and upgrade to ICS problem
Dear All,
I just bought new Experia mini pro (SK17i) last week, and install companion on my windows 7. its said later that upgarde to android 4.0 is available for my phone.
i did upgrade, i like the look but not the problem came with it, below are the problems that came up :
1. Audio from speaker became terrible, its so low and noisy , before upgarde was fantastic. if I connect to earphone the sound is normal.
2. Camera also became terrible compare before upgrade
3. responsiveness of touch display decrease, should push a bit hard
4. havent check the other thing
Please some one inform me if there anything i should do to fix these.
Thanks for all the help
2 REPLIES 2
Hi and Welcome,
1), Repair your phone using pc companion
or
2) Repair using Sony update service and check it
PROBLEM SOLVED..!
using sony update kit ICS 4.0 upgraded to ICS 4.0.4  the only minus is still the sound quality low..also lag when opening call menu..
Thanks rishi
