Xperia M2 Problems
Sofia29120
Explorer
Xperia M2 Problems
For some time now my M2 will freeze and I get a "warning message" saying something along the lines of "process.com.android has stopped working" what is the problem and how do I fix it because it keeps happening when people phone me and it makes my signal vanish and the phone will continue to ring but I can no longer answer the call and have to turn phone off and on again. Really getting on my nerves now I have had the phone for a year now but the problem has been happening for probably more than half of that time someone please help me. Thankyou.
2 REPLIES 2
profile.country.RO.title
_alexdon_
You may need to perform a software repair using PC Companion.The process will erase all internal memory.You might need to charge your device for about 1-2 hours before so the device has at least 80% battery.
alexdon
SophiaW
Enthusiast
Hi soph1988, welcome to the community!
Follow @Alexdons advice and if it doesn't work then contact Sony Xperia Customer Care in your region as your phone may need to be assessed by a technician.
