I bought Xperia m mobile last week only. Now it getting hang. While hanging touch not working. After removing battery only i can use mobile :(.
The phone freezes or applications suddenly shut down
Note: To exit safe mode, restart the device.
There are a few things you should try first when you experience problems with your device:
Restart your phone to turn off all running applications and to remove memory blocks. Remove and reinsert the battery and the SIM card. Then restart your phone.
Update your phone to ensure that you have optimal performance and the latest enhancements. Read more about how to update and find latest software version.
Reset your phone to its original settings to remove memory blocks: Settings > Backup & reset > Factory data reset > Reset phone Don't forget to back up any important data saved on your phone!
even i am facing similar problems with my Xperia M.....My phone even turns off automatically by itself when it hangs
I have also bought this phone 2 weeks ago, and observed the same behavior, all of sudden xperia m gets freezed and we cant do any thing further. i have to remove the battery and insert again to work with phone. It really annoying with a sony product.
My phone got freezed for around 5 times in 2 weeks.
Any help/resolution is appreciated.
Thanks,
Rajesh
HIe friends,
if your xperia M is getting hang or becomes blue and getting restart automatically while unlocking the screen...........then i suggest you to dont use the screen lock wallpaper. this is the only issue i was having but now im rocking with ma xperia m:smileyapplause:
Suniel Jog
hie dud,
i suggest you to dont use screen lock wallpaper if you are using.
i hope it will work.
I just bought me Xperia M dual 3 day ago... And it just shuts off automatically , and before offing, the notification say "SD card safe to remove"!!!
I am facing same problem in my Xperia M, it's automatically switch off.
it's heating up too.
now it has achieved an automatic swiitch on-off system....what do i do???
