[Xperia L]Multi-touch not working.
ishanbhatnagar9
So it's been about 3 week's since i bought this device and so far i don't have a single issue with this device. But recently, i downloaded quite a lot of FPS games which require multi-touch (Modern Combat 4, Modern Combat 3, Gangstar 4 Vegas, Dead Trigger) and i am facing issue with all of them. Not lagging or anything, the games run without any problem at highest settings but the multi-touch dosn't seem to recognize two touches at a time.
To give a bit of a mental image of what I'm dealing with here, I go to play a game on my phone (one of the above) and so on one side I have the movement button's (Up, Down, Left, Right etc. and on the right I shoot/aim around the screen, well the thing is, if my finger is on a button on the left for the movement and I go to aim while at the same time continuing to move, movement stops and it treats my aiming side as if it were the only finger on the screen at the time. Though Multi-Touch tester (an app on play store) recognizes all the inputs. (screenshot below)
This is a very frustrating problem as i have neither dropped this device once nor has it got any kind of physical damage.
Really, Really need help. Is my device faulty or should i factory reset it including internal storage?
Please Help!
Thanking you,
Ishan
16 REPLIES 16
DeepanshKhurana
Hello Ishan
I have an Xperia L too and I tried using MultiTouch Tester and got accurate results. 1,2,3,4. Here are the screenshots.
So, this proves this is not a general bug. Consider updating though I still havent updated my phone even though the update is available (Im on .31)
Deepansh
ishanbhatnagar9
Thank you so much for your reply Slightly_smiling_Face I repaired my phone with sus. Even I'm on .31 didn't get the update though 😕 I'll try it out and see if the bug is gone!
ishanbhatnagar9
MC4 is giving the same problem but now when i move my player and then aim, it sense only the aim but when i aim and the move, it works perfectly!
Also facing a graphical on the status bar. Screenshot_2013-06-24-09-40-20.png
DeepanshKhurana
Hello Ishan
The issue you told with MC4 happens in my cousin's Samsung Galaxy S4 too. Its not the phones bug if the multi touch tester works after the SUS Repair. Also, the do you use some launcher because this doesnt look like the official interface to me. If yes, did you try disabling the launcher and using the default one because I've never got this or similar graphics glitches. Been using the phone (Xperia L) over one month now.
Deepansh
MEZesUBI2
Hello! I am an Xperia L user too, with the same problem. Researched with the debug/developer mode, and found out, that if you point your fingers at once, and pull them in an indifferent direction, the action will be recognizable, but if you use a single finger pulled (like for movement) and then touch and pull with the other hand, the action before goes null, dissapears from the memory (the pulled line disappeares, more simply the movement goes out and aiming/action remains), yet both touches are still recognized. I assume this is a software optimization error (memory) and ask from Sony to release a fix for it, or if there is some official/unofficial fix out there, I would ask for it.
Thank you very much!
UBI
Azrion
has this issue been resolved with recent update?
lukasvelozo
I hope so, because I'm also having some issues while playing games like Batman and Dead Trigger 2. It's impossible to walk and aim in same time!
chaz-
Hey.. have you resolved your problem?? how did you do it.. please help me to.. Please.
babakgol70
update your phone to 4.2.2 for fix this problem.
