When i power it on nothing happens no flashmode no recovery mode and no charge.
It happens whith the new sofware update i update it on pc companion and in the 80 % of the update installing my phone turns off and now no power on no charge no flashmode/recovery mode....
I'll suggest you to remove the back cover then press and hold the power key at the same time remove the battery for 5sec then reinsert the battery. try to power up the phone again to see if works.
But since it fail to update, i don't think you will mamange to bootin to the phone.
You may want to do a software repair with PC Companion to see if is able to help on recovering the OS.
are you spanish? i say it for your nickname is bandolero.
If you are spanish say it me in spanish pls if you arent spanish i dont care
