I tried to install an apps on my phone from google apps store. when installed an app called dhamma padaya and the moment it finish the installation my phone atempting to restart but its restarting completely. after the colourful loading screen nothing is happening its keep loading for hours and no end. this is the far it can go and nothing changing for hours.. plz help
Try performing a system repair as this will often fix issues - This will factory reset your phone
Start PC Companion and select Support zone then Update my phone/tablet then in Blue Repair my phone/tablet and follow the onscreen instructions - When prompted connect your phone still switched off holding volume down or back button - This should start the repair or reformat process
