kindly I need your support in fixing my Sony Xperia l c2105 .
my mobile does not charge and I did the safe mode and format the mobile by using factory restore and nothing happen and using Sony charger and original USB cable and I put it in the charger for (8 - 12) hours and finally its 30% only and when I unplugged it from the charger it lose his charge very quickly and I changed the battery with an original one and nothing happen , what should I do ?.............
Please critically I need your respond as soon as you can .
Thanks a lot for your help
BR, Ahmed Osama
When I connect charger to my xperia L, it shows charging light but battery level isnt changing
Hi @Mido_O, I'm so sorry to hear about your phone.
Are you charging your phone using a wall socket or a USB port? If you are using a USB port please try and use a wall socket instead.
If you have the possibility to try with another original charger or charger cable that would be great. I understand if this might not be possible but if any of your colleagues, friends or family members have a Sony Xperia device you can use their original charger.
If you still can't charge your phone, or charge it above 30% I'd recommend that you perform a software repair using Xperia Companion. This will delete all data stored on the internal storage so it's recommended that you backup using Xperia Companion before performing the software repair.
Let me know how it went!
first of all thanks for supporting ,............
1. i am charging in the both USB original cable and Wall socket charger.
2. i will try your advice today but after charging my device as soon as i can to make sure it's not below 80% and i will fed you back with the result .
Thanks alot Jonas
BR, Ahmed Osama
No problem, I wish you the best of luck!
